Best harness for electric fan retrofit?
Old 09-20-2018, 01:27 PM
  #31
I have a gauge for that
Atomic's Avatar
You need a custom tune to enable them permanently. The Tech2 can only do diagnostic and test functionality, not enable them like factory.
Old 09-21-2018, 01:30 AM
  #32
Custm2500's Rude Friend
1FastBrick's Avatar
05 was the first year for the 2 pin connector on the alternator on the trucks.
RPO code KG3 for the 145 amp alternator.
Old 09-28-2018, 10:18 PM
  #33
stroker87's Avatar
I have installed the efans in my 04 shorty 4.8 used corvette/camaro fans built my controller (about $30)
have LED headlight/fog lights, JL audio sub and amps usually cranked up stock 105 amp alternator no issues slight drop on the volt meter when they kick on but my z06, my camaro, my friends 2012 & 2014 silverado's all do it an those are factory installed
i can cruise in traffic radio & A/C blasting knock on wood no problems
Old 03-09-2019, 03:39 AM
  #34
Registered User
Jorge Parra's Avatar
Originally Posted by RPMSpeed Tech
The nelson provides the best current capacity and higher quality wire and relays and even grounds vs stock.
The biggest issue is normally people dont upgrade the alternator and do not change the tstat at the same time. Most trucks with the fan clutch have the lower output alt. Upgrading that as well as the anemic power cable from the battery junction box helps out significantly.
We will be working on a heavy duty hybrid with upgrades that includes everything needed but is alot cleaner than the nelson harness.
Why Is it important to change the thermostat and which one should be used when upgrading to electric fans?
Old 03-09-2019, 05:40 PM
  #35
Nick99Chevy's Avatar
I didn’t change the t-stat when I did my fans and it runs at exactly the same temp as before.
4ws f 7 (08-15-2020)
Old 03-11-2019, 11:47 AM
  #36
00pooterSS's Avatar
There's no need to change the thermostat.
