audiobahn amp
i have 2 l5 solobaric 12's in the kicker box and a audiobahn 1300 mono class d amp. i dont know anything about the adjustment screws on the amp or what would be a good setting to put them on. can any one tell me what would be a good setting for all the adjustments for good mid to low bass. hope someone can help me out.
tell me what the different adjustment setting prefixes are and i will help you out.
ex.(hpf, lpf, bass boost, ssf, etc.) |
first problem audiobahn amps are trash. (cool looking flames i guess though) but my point is, these amps are for more show the anything.. the 1300 is probably at 1ohm. depending if your L5s are 2 or 4ohms you could probably turn the gain all the way up
it is best to set the gain with a volt meter but tell me the settings you have and we can get in the ballpark.....i dont like to set the gain by "eyeballin" it, but the other settings should be fine.
