to all 04 05 screw owners.
Old Jun 28, 2005 | 06:20 AM
one03sierra's Avatar
Formerly one92rs
Talking to all 04 05 screw owners.
if you are planning on amping out the speakers ion your new screw and want to run wires all the way to the speakers in the door--be prepared. there are plugs that go from the door to the body. i had to find empty slots in mine and drill out the holes for the 14 guage wire to go thru. what a pain in the ****. but it sounds way better. ill get some pics later.
Old Jun 28, 2005 | 03:40 PM
I ran my wires through the factory flexy rubber pieceon my 04, just unhooked them and ran it through with a big long think screwdriver.
Old Jun 28, 2005 | 04:45 PM
Formerly one92rs
Talking
ok here are some pics of what i had to do. granted these are only the back doors due to the ease of the pics. the front requiered much more diassembly.
this is a pic of the plug in the front door.
http://img.photobucket.com/albums/v1...i/MVC-094S.jpg
here is a pic of the loom for the back door.
http://img.photobucket.com/albums/v1...i/MVC-095S.jpg
here is a pic of the plug that goes into the body. as you can see there is no room around it to the rubber loom boot to run wires.
http://img.photobucket.com/albums/v1...i/MVC-097S.jpg
here is a pic of it pulled away. again as you can see no room.
http://img.photobucket.com/albums/v1...i/MVC-098S.jpg
so here was my solution. drilled out blank pin spots to accomadate the 14 gauge wire. then fed it thru.
http://img.photobucket.com/albums/v1...i/MVC-099S.jpg
and another with the plug seperated.
http://img.photobucket.com/albums/v1...i/MVC-102S.jpg
for those that have an 04 05 supercrew new body style i figure this will help out. i have only seen four other supercrews and they were the same. if yours is different lemme see them. man this was a small chore. the rear ones werent to bad. but the front!!! first off the parking brake foot lever assembly hasd to be unbolted and moved out of the way on the drivers side. then remove the boot and then the plug. on the front the lever you see one top folds back releasing the plug. there is a little silver tab on the bottom of the plug remaining in the door frame that has to be pushed up to get it to come out to drill it. on the pass side you have to unbnolt the fuse box assembly to gain access.
Old Jul 1, 2005 | 01:26 PM
my bad.....I was thinking U ment crewcab as in chevy/GMC...sorry still not used to this every make on the site lol
Old Jul 5, 2005 | 01:18 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
What size wire is it from the factory? I know on the chevys the factory wire is plenty good enough unless you are going for competition kind of stuff.
Old Jul 6, 2005 | 09:58 PM
Formerly one92rs
Talking
my factory wires were 18 to 22 gauge.
03sierraslt
14
Oct 9, 2015 05:53 AM
kmcn47
Sep 17, 2015 01:12 AM
GM1697
Sep 9, 2015 10:31 PM
GM1697
Sep 9, 2015 01:52 PM
smokeshow
Aug 23, 2015 08:23 PM
