2007 Classic HD cluster issue
Old Dec 31, 2019 | 06:47 PM
AlbertaZ71's Avatar
Default 2007 Classic HD cluster issue
Hello,
the instrument cluster on my 2007 Sierra Classic seems to not operate when it is cold. I had it rebuilt locally with new stepper motors and the connections checked and everything seemed fine until today when my truck sat out in the cold for a few hours. The back light for The instrument cluster would come on but I would have no gauges and no driver info center. Besides possibly being a bad connection with the plug is there anything else that could be causing this problem?
Old Jan 2, 2020 | 05:28 AM
ILuvJDM's Avatar
Try cleaning the grounds that are on the body mount beneath at the front of the drivers door. I had weird issues with my daily driver of 200k miles where it would turn the cluster off and flash all kinds of warning lights. I cleaned those grounds and resecured them, then sprayed black paint to keep it protected. Zero issues since that was done. It's worth a shot on your truck and only takes 10mins max
Old Jan 2, 2020 | 09:03 AM
madmann26's Avatar
There's more to fixing the cluster than just replacing stepper motors. There are a couple of key areas that need to be fixed in the board as well.
Old Mar 11, 2020 | 03:09 PM
AngryBear's Avatar
Originally Posted by AlbertaZ71
Hello,
i had a similar issue with my Tahoe when my power supply took a dump. You’ll see a bad solder joint in the power supply next to the driver info display. The power supply is super cheap. Just solder a new one in.
speedie mc pete
Feb 1, 2014 09:38 PM
superslo04
May 10, 2012 02:25 AM
NextLevel
Dec 2, 2010 08:34 AM
sierra69
Jun 16, 2010 08:12 PM
EVILGMC
Feb 26, 2009 02:06 PM
