1100rwhp Twin Turbo SRT
Thanks for the vid!
:eek2: :eek2:
Why would someone use Ebay to sell it, and they except PayPal. If I bought it, my monthly payment would be $2,000-$3,000 /month for 4 years, plus that much in gas :eek2: . |
Wow, that gotta be a fun ride. Leave it to Hennessey.
10.8s :eek2: nice...
uhhh...thats fast as hell , even tho its a single cab they are heavy!
Couldn't you build a twin turbo SRT10 for WAAAAAAAAAAY less than that?
Lets say you actually paid the MSRP of $52,000 on a truck like that from the dealer (which no one in their right mind would) ... does it really take $43,000 to get that same setup? Seems a little overpriced IMO. |
Lets say you actually paid the MSRP of $52,000 on a truck like that from the dealer (which no one in their right mind would) ... does it really take $43,000 to get that same setup? Seems a little overpriced IMO. They probably have that much in it but you could just turn up the boost and not do alot of the little stuff and be making more power. :judge: I do want to know where they got the slicks and what size are they. Did they have to use smaller rear rotors? :drive: Here is the mod list: Venom 1000 Twin Turbo Engine Upgrade ($65,000) 522 CID Stroker Motor JE Forged Aluminum Pistons (9.0:1 compression ratio) JE Pro Forged Steel Wrist Pins Manley Pro Forged Steel Rods ARP 2000 Rod Bolts Custom Machined Factory Crankshaft (exchange) Polydyn Coated Rod Bearings Computer Balanced Rotating Assembly Twin Garrett Ball Bearing Turbos Front Mounted Intercooler Polished Stainless Steel Inlet Tubes Custom Intercooler Hoses with T-Clamps Stainless Steel Turbo Headers Stainless Steel Turbo Down Pipes External Wastegates Stainless Steel Side Exhaust System Upgraded Hydraulic Lifters Upgraded Fuel Injectors Upgraded Fuel Pump & Fuel Lines Upgraded Fuel Pressure Regulator Centerforce Clutch Upgrade VDO Boost Meter Mobil One 15/50 Synthetic Oil & Mobile One Filter All Necessary Gaskets & Fluids Air/Fuel Calibration Exclusive Venom 1000 Twin Turbo Exterior Emblems Exclusive Hennessey Emblem on Rear Bumper Serial Numbered, Limited Edition Dash Plaque Professional Installation Road Testing & Chassis Dyno Testing Hennessey Performance Wheels Venom 6R 22x10.5 in. Polished 3-Piece Aluminum Wheels ($4,950) Hennessey Lowering Kit (2 in. front & 1.5 in. rear) ($1,750) |
They most likely removed the rear rotors entirely for that run. It takes an 18" rim to clear the stock rear rotors.
That truck only costs that much because it's Hennessey's. The best of the best as far as Viper tuners go. So yeah, you could do it alot cheaper, but then it wouldn't be a Hennessey. :hail: |
