RPMSpeed's new LEADFOOT Heavy Duty Stainless Valves
Alright guys, in our spare time between installs, sales, porting, partying, and watching cat videos on the youtube, we are churning out new parts all the time! This time is heavy duty stainless valves.
FOR MORE INFO EMAIL, PM, OR COMMENT
RPMSPEEDTECH@GMAIL.COM
So let's get down to the important points
Sizes
Intake valves
- 2.000
- 2.020
- 2.055
- 2.165 (solid stem)
- 2.200 (hollow stem)
- 2.250 (hollow stem)
Exhaust valves
- 1.571
- 1.600
- 1.615 (hollow stem)
As you have guessed, the 2.200/2.250/1.615 valves are made for ls7 heads and have std ls7 valve height to drop in. 2.165 intake ONLY AVAILABLE IN SOLID STEM AT THIS TIME.
I will get actual weights soon.
We are currently listing these on the site BUT here is the pricing.
$99 for each set of intake and exhaust for the 2.000/2.020/2.055/2.165 and 1.571/1.600. The ls7 valves are CRAZY priced at $329 for 2.200/2.250 and $279 for the ls7 1.615 exhaust valves. (Call or email for special ls7 pricing)
Now for the info!
RPMSpeed introduces our brand new stainless valve line: LEADFOOT. We all know why they are called that! These heavy duty EV8 23-8n stainless valves with hardened undercut stems and slip flow backcut design allows for the best cylinder head port flow and most efficient intake and exhaust port discharge. More air in plus more air out means better power!
Perfect drop in for any set of stock or aftermarket heads with no issues with seat alignment. Throw all the boost and nitrous at them your pistons can handle! Works with any spring even solid roller setups. STD 8MM (.313) valve stem and precision machined bead lock. Extra thick margin for heat dissipation and fatigue/distortion resistance.
So next time keep your LEADFOOT in it!
And also some pics!
Sizes
Intake valves
- 2.000
- 2.020
- 2.055
Exhaust valves
- 1.571
- 1.600
Now for the info!
And also some pics!
RPMSpeed Tech
21
09-13-2017 07:59 AM
moregrip
06-21-2006 01:31 PM
