Sponsor's Announcements, Sales, and Specials This is for our site sponsors to make announcements
New 5.3 boost prep budget long blocks!
Old Oct 4, 2018 | 09:29 AM
Strictly Performance's Avatar
Former Vendor
Default New 5.3 boost prep budget long blocks!
Based on a Gen 4 or Gen 3 5.3L GM LS series engine, this budget setup bridges the gap between a "junkyard build" and a fully built, forged internal performance engine. Professionally machined and assembled in house, our BoostPrep engines offer an effective solution for today's popular forced induction setups on the GM LS platform.
Utilizing the factory 5.3 block, crank, Gen 4 GM connecting rods, OE replacement pistons with a high quality skirt coating and hard anodized top, this engine is capable of handling 800+ HP. Couple that with all of the performance upgrades included in this engine and you're ready to throw on a turbo and turn it up!
Performance Upgrades
- BTR/LJMS Turbo Cam
- CNC Ported Heads
- BTR Dual Valve Springs
- BTR Hardened Pushrods
- ARP Head Studs
- Upgraded Trunnions
- Melling High Pressure High Volume Oil Pump
- New OE Piston Rings Gapped to .028 top and .030 Bottom
- King XP Rod bearings
- King XP Main Bearings
- LS7 Lifters
New/Replaced Parts
- Reconditioned Gen 4 Connecting Rods
- Hard Anodized Top OE Replacement Pistons
- OE MLS Head Gaskets
- New Lifter Trays
- New Oil Galley Plug
- New Coolant Plugs
- New Balancer Bolt
- New Timing Chain
- New Cam Bearings
Machine Work/Prep
- Iron Blocks are Baked, Blasted, and Painted
- Cylinders are Bored and Honed using a Torque Plate
- Engine Block are Decked
- Cylinder Heads are Resurfaced
- Multi Angle Valve Job
- Crankshaft Polish
- All Components Hot Tanked and Final Washed prior to Assembly
- Full Rotating Assembly Rebalanced on Gen 3 Configurations
No Core Required
Take $450 off the Price if We Use Your Good Core
Generally Ships in 2-3 Weeks
COST: $3995+ TAX AND SHIPPING
brewster240
Aug 27, 2012 03:13 PM
tommy grantham
Oct 14, 2010 09:20 PM
MDM@SDPC
Oct 1, 2009 08:29 AM
MDM@SDPC
Aug 27, 2009 11:50 AM
