99-06 GMT800 Solid AND POLY Motor Mounts
Truck Sponsor
We are happy to release our Solid Motor Mounts for 99-06 GM trucks! These are solid motor mounts that fit 99-06 GM LS-equipped trucks including Silverado, Sierra, Tahoe, Yukon, Yukon XL, Suburban, Denali, and Escalade. They are a direct bolt up using factory hardware. Custom feedback is there is only a slight increase in vibration or noise and most say it is barely noticeable. These are laser cut 3/16″ steel fully mig welded. All brackets will ship raw ready for your paint. They match factory measurements so the engine remains in the same location as stock.
The Poly version has the same mounting location but uses a larger bushing and 9/16" bolt to allow the engine and frame to rotate relative to each other reducing any potential vibration.
You can order through my website here: https://atomicfabandperformance.com/...m-fabrication/
Thanks and welcome to 2018!
rocknZ71 (01-01-2018)
