Props to Yank
sorry but good luck with their lock up on bigher hp/tq guys , they use a stock sized lock up and cost me alot of money . in turn blew my trans (failed lock up , not at wot but kess than 60 tps and it locked under a few psi and trans over heated , balloned converter enough to make it swell and push my crank forward enough to eat the main thrust bearing) i swapped to a converter with a much better/larger lock up , i have locked at wot many times and is running stronger than ever. imo.
although im sure they can work on mild hp motors , i would never lock it up and expect good. after i tried telling yank what happened and sending a file of my tune for them to inspect i still had to pay for them to rebuild my yank to salvage what i had invested. in short they told me i was doing wot lock ups and it caused it to fail , i didnt and i know it . swap to a convterter they dare you to break under any circumstance, that is what i needed.
my 2 dollars.
my 2 dollars.
exactly and i had the best 80e converter they had to offer back in 09-10 . if it works for you great and more power to you . mine didnt work for me and caused me lots of problems . i swapped and went with something better that worked for me .
that's basically what it boils down to, finding what works for you. Sorry you had all those issues, that sucks.
Yank has had an issue with their single discs burning up, I can verify that. And certainly not only under WOT lockup. My yank lockup failing last year caused a cascade of new transmissions...had that lockup not fried, my trans still would have been fine. And it never saw WOT lockup. DrX has also had this issue of a yank clutch failing under normal usage. From what I hear, it sounds like that issue has been fixed with their multi-disc, though.
I dunno how yalls tunes are setup but id advise you guys to get it to only lock under part throttle.. mine doesnt lock up till i get under 25% throttle so i can get up to speed and let out of the gas some till it locks then roll back in it so its not stressing the clutch.
Vortec350ss
Jan 12, 2016 10:36 PM
