Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Updated Sig.
Old Feb 21, 2007 | 03:21 PM
  #41
TurboGibbs's Avatar
Update:
Got it running but something is fugged up with my cooling system. I'm not getting any water circulation so i'll have to check into that later.
Compression has dropped a little to 11.5:1. The L92 heads have a different shape combustion chamber and I had to cut ~3cc's off the domes to clear the head. But it is a more pump gas friendly set-up now which is good.
Also, the idle is just where I was wanting it, almost stock.
Old Feb 21, 2007 | 03:23 PM
  #42
CHEVRACER83's Avatar
So Hows It Pull?
Old Feb 21, 2007 | 03:27 PM
  #43
TurboGibbs's Avatar
Originally Posted by CHEVRACER83
So Hows It Pull?
dunno? No water circulating ='s 3-4 miles worth of total driving it at a 1/2 mile at a time and let it cool for a few mins. each shot to get it back home. I had help with the cooling system install so maybe hoping the t-stat got cocked and isn't opeing or something like that. I'll look into it tonight but I have to drain the damn coolant and make a mess.....again!
Old Feb 21, 2007 | 03:53 PM
  #44
Thats Strange.... I Dont Really Think It Is Possible For The Thermostat To Go In Wrong.... Hopefully Its Just Stuck....
Are Any Of The Hoses Flat With The Engine Running??
Old Feb 21, 2007 | 03:54 PM
  #45
If I Were Closer.... I Would Come Help Ya Make A Mess..... Haha But Im Over Here In Gay *** Smog Law Hell California
Old Feb 21, 2007 | 04:13 PM
  #46
TurboGibbs's Avatar
Thanks, no hoses are suckin to. All really tight cause it would get to 240 I don't see how the t-stat could be in wrong either and not leak. I'll figure it out. But it's gonna make me start drinking!
Old Feb 21, 2007 | 04:22 PM
  #47
thunder550's Avatar
High on diesel fumes
You sure you just don't have an air pocket in there somewhere?
Old Feb 21, 2007 | 04:29 PM
  #48
TurboGibbs's Avatar
Could be. My expansion tank may not be venting properly since it is sitting at a serious angle now for some reason It has never sucked any water out of the exp tank since initial cold fill. They always suck some in due to air pockets. The pump could just be air bound due to the expansion tank cocked and it having the baffles inside it. I let it sit for 5 mins with fans on high and when I crank it the cold water in the radiator never makes it to the temp sensor and the temp just rises more as soon as I crank it. I'm 99% sure I got the head gaskets on correctly. They are labeled "FRONT" for goodness sake but maybe old Coors Light installed them???
Old Feb 21, 2007 | 04:31 PM
  #49
TurboGibbs's Avatar
The curse of the gay Texan just won't die.
Old Feb 21, 2007 | 04:40 PM
  #50
thunder550's Avatar
When I first fired up my motor it heated up at idle....although when I drove it around some it sucked all the coolant out of the overflow tank and I had to refill it. Did that a few times and the temps stabilized. I wonder if your WP is shot?
