Help me cam swap
I haven't decided when, but I am moving to North Carolina in 4 weeks so before then. It will depend on when I can get Charlie free to update my tune for the cam.
Parts I have:
Tools I need to borrow:
Post up if you might be interested in helping. FYI, I will provide beer as payment.... I will come to your place if you have the tools and would rather not cart 'em around and still bring beer. |
Autozone or Oreilly rent out a tool for the pulley. It's actually the Chrystler harmonic balancer puller, but it works like a charm! (thanks to Zzebes for telling me about that)
Also, you should buy a longer crank bolt for installing the balancer back on, then take it out and install the correct length bolt. I didnt use one to put mine back on, and it wobbles now, so I will need to pull it back off and re do it |
Add that longer crank bolt to the list of things to borrow or buy... I plan on renting the puller if nobody has one.
Dowels are cheap. When you get a puller, better make sure the bolts are high grade. Otherwise, they'll snap! :nod: Ask me how I know. ;)
Nate - I got a big ass screwdriver!! LMK if you need a hand.
i fyou don't already know, pick up some coolant and some motor oil.
Check and check for the fluids. I know dowels are cheap but I am extremely lazy. Thanks for the advice on the puller.
The main hold up will be when I can get together with Charlie for a retune, he is a busy dude. He said he would help with a swap when the time came, but that was before this dumbass hurricane. Though with this cam I cuold probably run it with my current tune for a while without problem. |
you can get the dowels at a lumber yard.... cheap ass little wood sticks for like .30 a piece... thats what i used... cant remember what size though
Spring tool - sold :(
Dowels - don't waste your 60 cents, they do not lock the lifters. You will be doing the russian roulette method with the false assurance that the dowels are going to save your ass. The JPR tool is designed as a semicircle for a reason - dowels do not do the same job. You don't have to take my word for it tho:) |
Originally Posted by 00ChevyScott
(Post 4006118)
Also, you should buy a longer crank bolt for installing the balancer back on, then take it out and install the correct length bolt. I didnt use one to put mine back on, and it wobbles now, so I will need to pull it back off and re do it A stock bolt is perfectly ok. Use a propane torch to heat up your balancer and she slides right on. :D Nate- Gimme a call if you need any help. |
