John's List
Old Jan 29, 2013 | 08:37 PM
Duntov1967's Avatar
Default John's List
Prices do not include shipping. I accept PayPal only.
The prices reflect current economic conditions and I believe them to be more than fair. If anyone wants to negotiate a little that is fine but I will not respond to low-ballers. Thanks for your understanding.
Please refer to item numbers when PMing me. Also, please list the item numbers in the PayPal comments area and pay quickly.
1. Whipple idler spacers (new) $8
2. Whipple/Gates 6 rib, smooth, 76mm diameter, smooth idler (new) $11
3. Whipple 6 rib overdrive alternator pulley (new) $15
4. Whipple 4 inch, 6 rib supercharger pulley (new, has been mounted once but not ran) $70
5. Whipple 70mm, 6 rib idler pulley (new) $30
6. Whipple 70mm, 8 rib idler pulley (new) $40
7. LS1 front steam cross-over pipe (used) SOLD/evilz99
8. Early LS1 4 port coolant vent lines (used) SOLD/stall
9. LS cam cover (used) SOLD/evilz99
10. LS6 valley cover, GM 12577927 (used but only on motor for 3 months since purchased new) SOLD/evilz99
11. LS1 valley cover, once polished but now grungy (used) $10
12. Alternator with overdrive pulley (used, about a year old) SOLD/evilz99
13. Electric radiator 7 blade fan from a 2006 truck (used for 3 months since bought new) $20
14. Kent Moore LS engine lift brackets #J41798 (used) SOLD/jgreen-fsi
15. LS1 lifter guides (used for 3 months since purchased new, comes with new bolts) $20
16. GMT 800 knock sensor harness (used) $10
17. GMT 800 coil harnesses (used) SOLD/oldtimelt1
18. Whipple NBS intercooler coolant tank mounting bracket (new) $15
19. Brackets for mounting a Tru Cool 40k transmission cooler to a GMT 800 (used) SOLD/hsiriyob
20. GMT 900 6.2L oil pan, pickup and windage tray. (Pan is new, all else is used) $65
21. Early GMT 800 oil pan, pickup and windage tray. (used) $50
22. VDO #150-101 boost gauge with line kit. (new) $25
23. NGK Iridium TR6IX spark plugs, set of 8 (new but no packaging) SOLD/v8pwr
24. GMT 800 cam sensor (used) $5
25. GM evap switch/solenoid used on many years (used) SOLD/Ferocity02
26. GMT 800 brake pedal pad (new) $5
27. Thermostat with housing from a 2011 Camaro, (new) SOLD/baggins
28. Jet Powertech high flow thermostat, 180 degree (used but only on running motor for 3 months) SOLD/stall
29. LS2 timing chain guide w/bolts (used but only on running motor for 3 months) $10
30. GMT 800 85mm Delphi MAF sensor (new) SOLD/theoneeyedbandit
31. GMT 800 ECM from a 2002 Tahoe (used) SOLD/TIM Z
32. Intake tubes & coupler from a GMPP system (used) SOLD/TIM Z
33. LS1 valve covers (used but comes with new gaskets) SOLD/TIM Z
34. Various Airaid 4 inch left over cut-to-fit intake tubes/silicon coupler/clamps from past projects. (new) $50
35. Spectre Performance polished aluminum air intake tube #9709 (new) $8
36. Gates 6 rib serpentine belt #K060962 (new, came with my Whipple kit) $20
37. Fleet Runner HD 8 rib serpentine belt #K081102HD (new) SOLD/TIM Z
38. Wiseco 402 ci piston set, #K445XS, -15cc dish, for 6.125” rods, 4.005” bore,4” stroke (used, no rings, some wear through on the skirt coating) SOLD/novaflash2002
39. GMT 800, 5.3L dampner (used for 3 months on running motor since purchasing new) $25
40. GMT 800 85mm Delphi MAF sensor #25160491 (used) SOLD/yonerhottlt1
41. GMT 800 2500/Hummer H2 front upper ball joints, pair (new) $20
42. GMT 800 radiator fan w/HD clutch (used for 8 months since purchasing new) $40
43. Summit brand piston ring filing tool (used for 2 builds) SOLD/shawnss
44. Manley chromoly piston wrist pins, # 42242 (2.300" x .130" wall, .927" dia., 95 grams) (new) $35 SOLD/v8pwr
45. ACDelco fuel filter #GF652F/GM89058397 (new) $6
46. NBS headlight, passenger side, w/one adjuster & 2 bulbs, clear, shiny with no haze. (used) $15
47. NBS headlight, passenger side, w/one adjuster, bucket & 1 bulb, clear, shiny with no haze. (used) SOLD/allenboy
48. NBS headlight, driver side, w/one adjuster, bucket & 1 bulb, clear, shiny with no haze. (used) SOLD/allenboy
49. Manley LS3/L92 Platinum Series 416 ci pistons, #592770C-8, 4.070” bore, 6.125 rod, -10cc (new) SOLD/v8pwr
Old Jan 29, 2013 | 08:44 PM
hsiriyob's Avatar
well done post!
Old Jan 29, 2013 | 08:50 PM
03sierraslt's Avatar
Now that's how you do a for sale ad!
Old Jan 29, 2013 | 09:08 PM
TIM Z's Avatar
11 sec. Truck Mod
Yeah awesome list !
I ll take the Tahoe PCM , the HD 8 rib belt and , and items 32 and 33 , the valve covers and GMPPintake tube. .
Please PM me a package deal on these items , pay pal ready , zip is 44662.
Thankyou !
EDIT : pay pal sent , thanks John !
Old Jan 29, 2013 | 09:13 PM
Ferocity02's Avatar
Amazing post. I feel like I should buy something even though I don't need any of these things
Old Jan 30, 2013 | 12:52 AM
Duntov1967's Avatar
Donations are accepted!
Old Jan 30, 2013 | 01:03 AM
ak2007r6's Avatar
Holy ****, everyone should follow suit with how you did your post when selling items
GLWS
Old Jan 30, 2013 | 07:16 AM
Duntov1967's Avatar
Morning bump!
Old Jan 30, 2013 | 10:34 AM
chevyridinhigh22's Avatar
Holy shiz, bump for a nice ad. Looks like it took awhile!
Old Jan 30, 2013 | 11:26 AM
ss4chad's Avatar
12 Second Club
I'm compeled just to give you money!
Nice post man, GLWS!
Chad
