2008 sdilverado dtc
Old Dec 19, 2008 | 10:03 PM
08blackchevy's Avatar
Default 2008 sdilverado dtc
my service engine soon light came on this morning the dtc is p1133 what does this mean?
Old Dec 19, 2008 | 10:17 PM
Please help
Old Dec 19, 2008 | 11:43 PM
BlownChevy's Avatar
blownerator
25 Year Member
#08-06-04-045A: Malfunction Indicator Lamp (MIL)/Service Engine Soon (SES) Light On, DTCs P1133-HO2S Slow Response Bank 1 Sensor 1 and/or P1153-HO2S Insufficient Switching Bank 2 Sensor 1 (Reprogram ECM) - (Oct 15, 2008)
Condition
Some customers may comment that the MIL/SES light is illuminated.
Upon further investigation, technicians may find the following Diagnostic Trouble Code(s) (DTCs ) stored:
• P1133 : HO2S Insufficient Switching Bank 1 Sensor 1
• P1153 : HO2S Insufficient Switching Bank 2 Sensor 1
Cause
This condition may be caused by the use of gasoline that exceeds the 80 Parts Per Million (PPM) maximum U.S. Federal guideline for sulfur content, but is within the 80 PPM - 450 PPM sulfur content special exemption allowed for small U.S. refineries and/or the greater than 80 PPM sulfur content fuels found in other parts of the world. In Canada, federal regulations limit the sulphur content for gasoline sold in Canada to 80 Parts Per Million (PPM) maximum with no exemptions.
Correction
Important: Verify that the 12-volt battery has a battery charge of 12 to 16 volts. The battery must be able to maintain a charge during programming. Only use approved Midtronics PSC-550 charger/maintainer or equivalent to maintain proper battery voltage during programming. The J2534 MDI will reprogram the modules in less time than the Tech 2® scan tool.
A revised engine calibration has been developed to address this condition, which is titled "New calibration with diagnostic enhancements for DTCs P1133 and P1153." Technicians are to reprogram the Engine Control Module (ECM) using the Service Programming System (SPS) with the latest software available on TIS2WEB. Refer to the Engine Control Module Programming and Setup (Gasoline Engines) and Service Programming System (SPS) procedures in SI for more information. As always make sure your Tech 2® is updated with the latest software version.
Old Dec 19, 2008 | 11:44 PM
BlownChevy's Avatar
blownerator
25 Year Member
In other words, take out the HPT, hope they do not see that the vehicle has been modified and take it to the dealer for the PCM update.
calsdad
Jun 14, 2023 11:07 PM
drummer0415
11
Oct 24, 2015 08:16 PM
Closer_2001
Sep 24, 2015 09:15 PM
Velocity1
Sep 22, 2015 01:32 PM
creekrat
Sep 10, 2015 12:59 AM
