LS garage cleanout
Old May 27, 2018 | 10:24 PM
hodge9386's Avatar
12 Second Club
Default LS garage cleanout
C5 batwing oil pan with windage tray and pickup: $200
Ls6 valley cover with PVC: $40ea
LS1 coils with brackets and harness: SOLD
LS1 painted valve covers: $40
NNBS truck intake with rails, flex fuel injectors: SOLD
85mm maf :$30
75mm maf :$30
C5 single gauge pod :$20
Comp Cams double row timing chain: SOLD
Ls2 fuel rail with LS2 injectors: $200
243 heads lightly hand ported with BTR .660 dual springs, needs new valve seals (ill clean them up and put new seals on them before i ship them) :$600
99 C5 PCM :$150
99 ls1 5.7 block with all internals, front and rear covers. Had 45psi oil pressure before I took it out. Tom and engine supply measured the cylinders and they are out of round but they will work fine with a .010 over bore. I have a new set of king si STD rod and main bearings that will go with it :SOLD
All items are plus shipping from Savannah ga.
Old Jun 3, 2018 | 09:01 PM
hodge9386's Avatar
12 Second Club
Bump. Items updated
TrickTurbo
Jun 28, 2009 09:16 PM
thunder550
Aug 10, 2008 11:22 PM
10RamSport
Oct 29, 2007 08:17 AM
JT-bo
Nov 1, 2006 07:38 PM
