TBSS Intake with Fuel Rails and 36lb Injectors
Old Aug 26, 2017 | 05:21 PM
Gbrown1320's Avatar
Default TBSS Intake with Fuel Rails and 36lb Injectors
Up for sale is a TBSS/NNBS truck intake manifold, including fuel rails, high flow 36lb injectors, Evap solenoid, Evap line, map sensor and retainer, and a set of intake bolts. The intake does have a minor cosmetic blemish where someone had attempted to remove the vacuum fitting for the brake booster (see last photo). The fitting has been marred from a pair of pliers. However, the fitting has been inspected and is functionally fine, it's purely a superficial blemish.
$290 shipped anywhere in the continental US.
I ship via FedEx ground, insured for full value, which typically arrives in 3-4 business days or less.
Great upgrade for the 99-07 Silverados with the smaller throttle body and intake. This is the intake with the 90mm TB opening. One of the best flowing factory intakes available. People claim the intake is worth 20+hp over the factory 78mm truck intake on 99-07 trucks
