'85 c10
Old Dec 13, 2016 | 11:55 PM
lowchevytrucks8503's Avatar
After heating it up and twisting it
Old Dec 14, 2016 | 04:47 PM
  #22
Spent some time today getting the Wamrods hood struts installed. Still have to make two minor notches in the hoods but the rest is done!
Inside passenger fender
Passenger side of the hood
Old Dec 14, 2016 | 05:57 PM
  #23
stroker87's Avatar
thats pretty cool
Old Dec 15, 2016 | 11:34 AM
  #24
Originally Posted by stroker87
thats pretty cool
Yes Sir! Check them out! They have some for the 88-98 Body style as well. Wamrods is the brand.
Old Dec 16, 2016 | 05:19 PM
  #25
Finished up the Wamrods install! This setup is awesome and great quality along with the instructions
Old Feb 9, 2017 | 03:04 PM
  #26
Ditched the junkie oem throttle cable. Went with a 72-72 C10 Billet gas pedal. Fits squarebodies with no modification.
Old Feb 12, 2017 | 10:12 AM
  #27
Ordered a Circle D 278mm 3000-3200rpm stall convertor for my 80e swap! Hopefully it will be here Monday. I also ordered a TCI flexplate SFI rated. Part #399753, this one is a direct replacement for the ls1 flexplate. If you want to go with one that has the pattern for a 4l80e, then order part #399754.
I had to order this TCC switch from PSIConversion, since I wasn't aware I needed it when I ordered my harness.
Old Feb 12, 2017 | 10:14 AM
  #28
Can anyone recommend which deep pan for the 80e I should get?
And which dust cover?
Old Feb 17, 2017 | 11:30 PM
  #29
Got the Circle D stall convertor in the other day. It's a 278mm 3000-3200 rpm with the 3 bolt pattern for the ls1 flexplate. Also got the TCI flexplate #399753.
Old Mar 27, 2017 | 09:49 PM
  #30
One of the 243 heads I got back from
The machine shop. With the Lunati dual springs
