GM SUV rear airbag over axle setup, 2500# firestone bags, brackets, lines etc. CHEAP
Old Jan 30, 2017 | 09:24 AM
ThatDudeOrion's Avatar
Default GM SUV rear airbag over axle setup, 2500# firestone bags, brackets, lines etc. CHEAP
All airbag parts still available
2x Firestone 267c 2500 pound, single 3/8 npt port bags
1 set of GM SUV 00-06 bolt on air bag brackets and all hardware. These have been cut down on an end mill to be the correct length (height) when used with the bags above, to have a ride height around a 5-6" rear drop, with a good amount of air pressure in the bag which should approximate the spring rate / ride quality of stock or lowered coil springs. Also the bag brackets have been machined in such a way that one is slightly taller than the other to correct that trademark drivers side chevy lean.
also comes with air line and all fittings to run to Schrader valves on the back bumper. I wasn't going to do a fancy air management system just for the back, since I was planning on using coilovers on the front.
All the above can be yours for $125 shipped OBO
Picked up in person in Trenton, NJ or Harrisburg, PA
Old Feb 6, 2017 | 02:08 PM
not getting much interest, price drop to $100 OBO.
Old Feb 9, 2017 | 03:28 PM
ScottyBoy's Avatar
I'm a bit confused as to what exactly this all is.
Is this to add helper bags? Or is this everything needed to actually remove the rear coils and put airbags in place of them?
Old Feb 9, 2017 | 03:56 PM
arthursc2's Avatar
Remove rear coils and put the bags in their place
Old Mar 24, 2017 | 09:43 AM
Btravis90's Avatar
still got all this?
Old Mar 27, 2017 | 07:22 AM
Sorry mate it sold on CL a while back, my apologies for not updating this thread.
Originally Posted by Btravis90
still got all this?
