Need help with bcm
I'm having troubles with my body control module sometimes all the gauges from the speedometer don't want to work. 2003 Silverado
Sometimes they turn on and sometimes they don't, I really don't know what can cause this. Maybe a bad ground? Or do I need to replace the Bcm? Help!
So you don't think it had nothing to the with the bcm?
Like the whole cluster don't turn on nor the gauges . Only thing that stays light up is the check engine thing . But I had that on before this happened . Like this whole weekend everything was off then Monday it turned on one time then it hasn't turned on since that day. Like it had this problem sorta before if this happened I used to tap on the cluster and everything will turn back to normal and I've tried tapping it and still nothing
I've changed the gauges motors last year and the lights from the cluster too
If the only light you have on is the SES light, you have a bad cluster. You may have replaced the motors and bulbs, but this most likely is a cold solder joint problem at the circuit board. I've replaced hundreds upon hundreds of these
