-   SHOW & SHINE DISCUSSION (https://www.performancetrucks.net/forums/show-shine-discussion-129/)
-   -   what engine degreaser/underhood cleaner? (https://www.performancetrucks.net/forums/show-shine-discussion-129/what-engine-degreaser-underhood-cleaner-474857/)
LS1TRUCKGUY Jan 2, 2011 08:11 AM
what are you guys using? I generally use simple green, but i have neglected cleaning under my hood for a while now, and i want to use something thats gonna cut through all the road grime and what not.
Rhino79 Jan 2, 2011 11:32 AM
Actually, Easy-Off oven cleaner works awesome.
TIM Z Jan 2, 2011 12:03 PM
Simple green.
Ive heard oven cleaner peels paint??
A couple cans of engine degreaser, then simple green and a pressure washer will clean up your engine/ compartment.
gs7793 Jan 2, 2011 01:28 PM
i use simple green and dont dilute is any....if you dont dilute simple green it does a ton better
LS1TRUCKGUY Jan 2, 2011 02:04 PM
I'm a little hesitant on the pressure washer... my luck I will get water in electrical stuff where it doesn't need to be... I might try some oven cleaner if it doesn't peel paint. What about the adams undercarriage/engine cleaner? Anyone use that stuff?
gs7793 Jan 2, 2011 02:08 PM
^you'll be ok with the pressure washer, just dont spray your coil packs or the other central electric areas....
skolman91 Jan 2, 2011 02:17 PM
unless you've already replaced and sealed up the knock sensors i wouldnt be going anywhere near the intake with a pressure washer or water for that fact, just my 2cents tho..
unless your planning on doing it in the future that is..
gs7793 Jan 2, 2011 02:23 PM
^and yes or course dont spray your intake lmao
skolman91 Jan 2, 2011 02:29 PM
I meant the intake manifold of course, but i think you knew that.
If you cant spray the intake, coil packs, fuse box and ecm, what exactly are you spraying with a pressure washer?? I guess my point is it doesnt leave much except for the pass side fender well area..??
LS1TRUCKGUY Jan 2, 2011 04:02 PM
thats kinda what i was thinking... at least the pass fenderwell will be clean. lol
i have always used simple green in the past, just seeing what else you guys are using besides that
