shaved door handle help
Old Jan 22, 2008 | 01:06 AM
perrco's Avatar
Default shaved door handle help
i just got the aut loc shaved door handle kit and i dont know what to do with the hole where the handles where. so what can i do
Old Jan 22, 2008 | 01:17 AM
wesley_burks's Avatar
well, if you didnt know this before buying the kit, you might be a little surprised. in order to make this whole thing work, you have to install the kit, then fill the holes with a plug and fiberglass, then bondo with grinding and sanding in between, the primer, then paint. its kind of a big deal.
Old Jan 22, 2008 | 11:15 AM
02BlueStepside's Avatar
Click here for the door handle fillers
Old Jan 22, 2008 | 12:15 PM
NHolds's Avatar
Best to use metal.... I think if you use fiberglass, after time you might see the seem lines. Lots of work either way.
Old Jan 22, 2008 | 01:02 PM
I'm sure he understands it's a big deal... but you are wrong there is no plug and you most certainly don't use fiberglass on a sheet metal door. You slowly stitch weld a metal filler plate in then slowly grind, the key is to keep the heat down while doing all this. Get it as close to finish product in metal and use as little filler as possible. Sand prime paint.
Old Jan 23, 2008 | 10:50 AM
silverdenali22's Avatar
Don't shave it is a big pain send the kit back. The silinoed will rust up and you will be locked out in a rain flood, get a window kit much better.
Old Jan 23, 2008 | 10:59 AM
BlackGMC's Avatar
Resident Retard
If I was doing this I would remove everything from the insides of the door before welding it, but that is just me. Also use a flapper style disc while grinding to keep the heat down, moving in long strokes.... Watch for heat burns in the metal when using the grinder....
cheyenne383
Nov 13, 2015 09:24 AM
smok'nZ
Oct 6, 2015 01:14 PM
turbo6c3
Oct 5, 2015 06:11 PM
BCraven1018
Oct 1, 2015 08:22 PM
JoshH
Sep 28, 2015 11:19 AM
