New shoes on the race truck
https://cimg1.ibsrv.net/gimg/www.per...97e9fa1274.jpg
https://cimg4.ibsrv.net/gimg/www.per...60f2a2fcac.jpg Finally got the new wheels mounted and installed. The front should sit as little lower when I put the front end and turbo back in |
nice Welds!...what size tires?
Love your build thread... Edit: Found in your build thread 295/65R15, so 30" tall tire... Did you need any special brackets to mount the 6.0 in a V6 truck? Im considering starting a similar build, if you could do it over again would you search for a V8 truck to start with? 4x4 truck? |
Originally Posted by 01FormulaTA
(Post 5439452)
Love your build thread... Edit: Found in your build thread 295/65R15, so 30" tall tire... Did you need any special brackets to mount the 6.0 in a V6 truck? Im considering starting a similar build, if you could do it over again would you search for a V8 truck to start with? 4x4 truck? I'd definitely find a v8 and 4x4 if i could do it all again! As for motor mounts they are factory mounts from a v8. |
