Just Bought My 2in Rear Drop
Old Dec 16, 2004 | 07:42 AM
  #21
ActionJackson's Avatar
Sierrasmooth...care to post your wheel/size stats? They look nice!
Old Dec 16, 2004 | 07:43 AM
  #22
Originally Posted by CAMMIN03
I hope it looks good...... How easy are these to put in.... its the shackle kind... i got it to even the rear with the front..... has anyone done this by themselves... maybe have some tips......
Where did you find these shackles for the two in. rear drop...I'd like to drop mine in the back end also.!
Old Dec 16, 2004 | 07:59 AM
  #23
smooth sierra's Avatar
they are centerline lancer 20x8.5" chrome plated. the tires are goodyear eagle LS 275/55/20. I would not recommend the goodyears. they are a little tall and do not hold a balance very well. I plan to replace them with a 275/45/20 once I wear these out.
the shackles I bought came from a local custom shop and they are DJM 2" shackles. there are several mail order and online vendors that carry 2" shackles for late model trucks and they seem to all be around $40-50 a pair. they are very easy to install and greatly inhance the looks and handling. I highly recomend them.
Old Dec 16, 2004 | 08:38 AM
  #24
CAMMIN03''s Avatar
Banned
thanks man.... if i have any questions Ill PM you... thanks alot..
Old Dec 16, 2004 | 03:31 PM
  #25
STOCK_SUCKS's Avatar
YOU MIGHT HAVE TO ADJUST THE SWING BEARING. I PUT MINE ON AND I HADE A BAD VIBRATION UP TO ABOUT 40 MPH. I CALLED BELLTECH AND THEY SAID I NEED TO BUY THE ADJUSTABLE SWING BEARING. SO I JUST TOOK THEM OFF FOR NOW TILL I CAN GET TO CRAWL UNDER THERE AN SEE IF I CAN SHIM THAT BEARING.
Old Dec 16, 2004 | 03:33 PM
  #26
pardon me for asking but WTF is a swing bearing?
Old Dec 16, 2004 | 04:35 PM
  #27
Sorry Drive Shaft Support Bearing
Old Dec 16, 2004 | 07:40 PM
  #28
CAMMIN03''s Avatar
Banned
well we will see.... I got it off JEGS for around 50 bucks shipped
Old Dec 19, 2004 | 12:08 AM
  #29
graystepside's Avatar
Just get a cutting torch and new bolts and you are good to drop.
Old Dec 20, 2004 | 06:29 AM
  #30
that would be called a 'carrier bearing' for future use. and it should not be adjusted as it is made to line up with the output shaft of the transmission. If you drop the rear far enough you should shim the rear axle with wedges to compensate for pinion angle. you DO NOT adjust the bearing.
