How to prep TPO for paint?????
Need help.....want to know how to prep a TPO (Thermoplastic polyolefin) bumper for maximum adhesion?:eek2:
1. wash item with a mild detergent 2. wet sand to my desired smoothness 3. spot putty a few gouges/fill, sand, smooth 4. wash item with a mild detergent 5. wash item with a wax and grease remover 6. apply Adhesion Promoter 7. apply primer 8. fix defects missed earlier that now show with a primer coat/this step would include another washing; wet sand to scuff the primer coat 9. apply color 10. apply clear |
11 wet sand again if needed
12 buff/finish for the final time, wax. Seems you gots a pretty good idea of what to do. Prep is key to painted, runs in paint and clear, can be dealt with after.. I would also add some type or get a paint made for bumpers( as it will have a flex additive, that will keep from flaking or cracking if flexed). You can X the first step, just start sanding.. Wet sanding will take longer then dry sanding, you do not want the surface totally smooth. It should be a little bit ruff, so the promoter has something to bite into.. :D I am prob leaving something out, but you seem to have it.. |
When washing before and after sanding use scalding hot water to wash and rinse as it will help release oils from mold that were used as a release agent.
Nice tips. Should be re-painting my grille and lower valance this weekend.
thanks for the tips! I still don't know if I'm brave enough to give this a go....but....I may just have to try it out!
If you have some more info please post it up! |
Just go with it.. Only one way to find out. worst case is you have to get it done again.. No worries
well with having access to the paint booth on base maybe I should give it a try???
I have adhesion promoter that says clear primer
Do u still need to primer I would think you would? |
| All times are GMT -5. The time now is 12:53 AM. |
