22" Tire Size Help
1 Attachment(s)
I have an 03 Silverado with 305 40 22 tires on all around. The fronts rub like hell with a 2-4 drop. I rolled the fenders but they still rub pretty good. If I buy 285 40 22 for the fronts, will it make any difference. Or would I have to go with something with less sidewall. I don't want less sidewall. Thanks guys
Depends on your rim offset. I have 285/40r22s on the front and they rub a little but I'm running a 3/6 drop so you may be safe given the extra inch.
I don't know what I was thinking above. I have a 3/5 drop with 305 40 22 all around with a 9.5" wheel. How skinny of a tire can you go on a 9.5" wheel?
I run a 265/35/22! It's got about a 3 to 4 inch firewall...I like it though! I can post pics tomorrow if you want or you can search iluvjdm on here and it's his old setup on his truck.
Yea I want to keep the 40 sidewall but will step down to the 35 if the 285 wide tire won't clear my 3/5 drop.
Originally Posted by blue2003ls
(Post 4829110)
Thanks! |
On my 2/4 I have no rubbing issues on a 305/40/22 Nitto 420, hmmmm?
(Post 4829111)
Originally Posted by Last Call
(Post 4829381)
Neil - Can you post some pics? I am buying new tires and torn between the 305/35 and 285/40.
Thanks! http://i267.photobucket.com/albums/i...lo/photo-2.jpg I liked my 285/35r22s a little better on the front but the extra sidewall makes for a better ride. |
(Post 4829623)
I am running 9.5" wide rims on the front and the 285s look great.
Here you go Jason... I don't have any pics of it on the ground right now but here it is up on jack stands. I liked my 285/35r22s a little better on the front but the extra sidewall makes for a better ride. |
Is that tire a 285/35 or 40?
(Post 4829623)
Here you go Jason... I don't have any pics of it on the ground right now but here it is up on jack stands. http://i267.photobucket.com/albums/i...lo/photo-2.jpg I liked my 285/35r22s a little better on the front but the extra sidewall makes for a better ride. |
