Supercharged,straight axled 03 2500hd
#301
Moved the mighty mouse catch can, hoses worked out nice with a 180 on the fill cap and a 90 at the can. Also added the drain extension hose so it down by the frame rail, way easier to empty now.
#302
Changed the oil from conventional 10w30 joe Gibbs hr to 10-40, oil pressure hot at idle I see 35 and would up almost 60. Also cut open the filter I pulled off and it looks pretty good. It has some dust particles but nothing crazy. So at least that parts food so far. The filter in the pics is still wet so you get glare, now that it's dried it looks much better and easier to see. Cutting the filters open with tin snips , I did see the wix filters have more pieces inside. The wix had a big rubber washer and s spring, the Delco didn't.
#304
Yea it seems like alot better filter, from looking at it anyway. The wix has a bigger filter area, looks thicker too. I know it was harder to cut and stiffer. The big rubber washer by the threads and the spring I dunno what that's all about. I ended up putting a acdelco 61 on tho because they didn't have the wix in stock. Here's the wix in the pic. From the filter media above to this one you see almost nothing on it, it's really clean....Exactly what I hoped for.
#310
Sorry i missed this, its apart currently. The trans is getting a few big upgrades, exhaust is getting a makeover and it should be tuned when i get it back. With this all done for sure it will run better and have better drive ability. I'll post more on that tho at a later date when i can give you better details along with pics.
