My truck
Old Jun 17, 2012 | 06:37 PM
darnie's Avatar
Originally Posted by custm2500
You have done all of this and not done a stall converter? Very backwards but atleast you are making some good power of stock. Once you get a decent stall you will have a pretty screaming truck.
Truck also looks great.
Lol i know i know. I was planning on doing it after the cam but had to do heads because my drivers side head was cracked but i got everything in place just need stall gears and start save n for a 4l80. I may do a 6.0 i wanna go boost but i wanna keep my heads and maybe cam idk how well they would work in a 6.0 vs 5.3?
Old Aug 16, 2012 | 11:52 PM
darnie's Avatar
Update..... well i find out monday if i get to add a few more mods to the truck
Old Aug 28, 2012 | 07:44 PM
darnie's Avatar
well these came in today now just waiting on my stall duel 14" fans 5050 cfm should be enough. ill try and post some pics of the install and how i build the shroud
Old Aug 29, 2012 | 09:01 PM
darnie's Avatar
Well i went to the store and came home to this
I also picked this up for $80 brand new in the box should be a nice addition to the truck as well
Old Aug 30, 2012 | 06:54 AM
darnie's Avatar
quick question.... so im going to be building the shroud for the fans out of aluminum im pretty sure. my idea is a to get a flat piece and to use some 1" or 1.5" square tubing and use self tappers and silicone to secure and fasten everything into place. now the best idea i have come up with is to use cardboard to make a template any other ideas on how to get one going? thanks for the help
Old Aug 30, 2012 | 08:23 AM
KC_kid's Avatar
Cardboard would be a big help making a template but I doubt you need too much of a "shroud", really just need something to hold the fans close to the radiator and provide a little support. Also, you can reuse the existing mounting bolts & holes that are already there holding your current shroud. That's what the f-body fans use and then just rest on the existing little shelf on the bottom of the radiator, no other attachment needed.
I also installed a remote start on my '01 Silverado, if you run into trouble I MIGHT be able to help, maybe not.. Good Luck, I like your truck, the mods and the write-up!
Old Aug 30, 2012 | 04:53 PM
darnie's Avatar
sounds good. how far back do the fans need to sit from the radiator? and kk sounds good
Old Aug 30, 2012 | 05:13 PM
KC_kid's Avatar
I can't answer that for sure other than not much? Take a look at how the f-body fans mount, you can see they don't sit very far from the radiator..
Old Aug 30, 2012 | 07:14 PM
darnie's Avatar
humm i wonder if i get alittle thicker piece of alum i can just cut holes for the fan and fasten it to that?
Old Aug 31, 2012 | 09:25 AM
KC_kid's Avatar
As long as it's not flopping around smacking the radiator, I don't see why not
