My iron 5.7 build
10 Attachment(s)
Started with a 07 classic 5.3 with full floating rods, Had block bored to 3.898 with flat top pistons, block deck and balanced rotating assembly, assembled with new stock 799 heads, LS6 head gaskets, Texas speed cam 212/218 .550 .550 on 114, Ls7 lifters stock push rods and rockers.
1 Attachment(s)
installing new motor...
Attachment 80363 Runs very will with the stock 5.3 software but need a tune, it some times dies and you can tell is very held back. No check engine lights on and factory fuel trims running about +3. running 93 octane until I get a tune but haven't had any knock counts. Who would be a good mail order tuner, I live in longview and don't trust anyone here. I most likely will be going with Nelson Performance in San Antonio. I have factory 05 electric fans and harness to install also after tune. |
Check out Atomic Fab and Performance. He's a sponsor on here.
Yes, he seems to know his stuff..
Did you upgrade injectors and/or fuel pump if your truck is not e85 capable? If not you will want to do that with the larger displacement and cam. Sounds like a great swap!
Originally Posted by 53bowtie
(Post 5408474)
later if I find and free intake off an 07 up I'll swap it. |
I commented in your other thread but if you want to do mail order tuning give Zippy a call and if you don't have access to HP Tuners you can license it on mine and I'll load the tunes and log it for you.
Originally Posted by Jermoslin
(Post 5408475)
Using stock truck intake and injectors off the 04 system, none E85 capable.
Nelson's Performance over here in Texas would be a good choice as well!
All great advise, I'll be checking on the 8.1 base injectors, I used neslon when I lived in Austin, but being 6 hours away now I don't see me driving to get a live tune. I think my best bet for me is save a get my own Hp suite software so I can data log and email to others and then start learning to tune myself.
