Kaane's 1999 Silverado RCLB Beater Build 6.0 Swap
#21
Pistons installed.
Camshaft installed, new arp bolts, new retaining plate. LS2 Chain. Melling Oil Pump.
Front cover aligned.
Couldn't get rear cover aligned, stupid alignment tool is too big and won't fit between the crank and the engine stand, going to have to attach it to a hoist and take it off the stand.
Started also working on the rockers, going to get the Straub trunnion upgrade kit installed.
#24
Started engine assembly.
Filing rings is a pain in the ***, took forever.
Set the Top at 0.020 and bottom ring at 0.022, I did mess one up bottom ring and went to 0.027 somehow. Ordered a new ring to fix that one.
Painted the block and installed the crank, torqued the mains.
I did notice some damage to the block oil pan sealing surface. I have one deep scratch and one smaller one. How should I handle it? Not sure if gasket by itself will fill that gap. Should I put a dab of RTV in those spots?
Torqueforce
08-14-2015 10:42 PM
