Bonjie 2011 Build begins.. sort of
#26
the 408 has been ordered!
Details here
Rotating assembly
Probe Pistons
6.200 rod
RPM Crank
RPM Rods
9.5:1 Compression Ratio
Camshaft
-224/228 .560 lift 112 LSA
2005 block
-ARP Head Bolts
-Main Bolts stock
Details here
Rotating assembly
Probe Pistons
6.200 rod
RPM Crank
RPM Rods
Camshaft
2005 block
-ARP Head Bolts
-Main Bolts stock
#29
hmm. i thought the rod bolts were the weak link of the LS bottom ends? i know its your build. but your already going big with everything else why not just add a little bit more insurance? well no matter what good luck with your build should run good. whats the over all goal anyways HP/ 1/4 times
