Black LSX
#63
Got the coil packs mounted to the crossmember and bolted back up. Need to create spark plug wires and route them somehow down there and out of the way of my headers.
#64
got my coil packs relocated. now hopfully the truck will start up correctly. If I were to do this again I will do it with engine out of truck, some parts were a pain in the ***. I unscrewed my fuel lines that were wrapped around the main engine harness to free it up and move it off the intake. I need some suggestions on how to keep the loom off to the side. Ideally do no want to punch anymore holes in the firewall if possible. Also going to start working on where all my hoses are routed and get them wrapped in techflex hose since they are ugly as sin. I will have to extend a couple of sensors when i get my engine harness off the intake as well.
Here is the loom I am trying to decide what to do with it
Driver side wires running down the engine and over crossmember
Passenger side wires looping back and around to avoid headers
Bottom of the truck where my coil packs are and with the new coil harness
Old harness vs new harness
#65
Was able to wrap up most of this little project before it gets cold and days are short. Truck started up and idled fine so my spark plug i made were good and my soldered job on fuel injectors, but I have a small leak in the fuel regulator because I have to take off a hose to move the harness. I am guessing bad o-ring possibly. I took off all the old plastic loom on what wires I was working with and used techflex which looks a lot better and mobility is more. I will do the rest later when i have engine out next or something because leaning over this whole time to do this sucked. PLEASE excuse the drivers side valve cover as I painted it long ago, and passenger side i had to get a new one and never painted it, driver side looks like ***. So I will either strip the paint and put something more durable on or pay for some nice ones. Next spring I may address my hoses that are running every which way.
my ECM harness got fixed up
Fuel lines look a whole lot better
#66
Been too cold to do much around here, but starting to gather a few small things to relocate my battery, remove junction box, and got a set of valve covers in. I bought them from holley and it took over months to get them in. After multiple calls found out they are built to order so they need to add that to the product description. I need to replace my header gaskets, and fix a leak in my exhaust because both are leaking pretty bad.
A bunch of stuff to relocate battery, welding cable, heat shrink, mega fuse etc
#67
When i did my t56 swap, found an article where someone was able to use a envoy, trailblazer, or s10 sterring column cover. Since they do not make the silverado cover for a manual truck, unless someone knows where one is. I bought a trailblazer and it seems to be too short on the top. THe hazard button isnt the same but that is fine.
Another item is does anyone know how to remove the metal part on the old automatic shifter, I need this gone in order to put the manual cover over it. There is a pic below.
#68
So did a few upgrades here the last month. I updated my valve covers to something newer and better looking to accommodate coil pack relocate. Removed my red junction box and upgraded battery cables to bigger gauge. Relocated my battery and ECM. Put in new header gaskets and wheel wells or whatever they are called. Installed a coolant crossover line. Want to thank silentbravo and firebladejj for helping with electrical suggestions along the way.
Here is my old crappy valve covers i tried to paint
Got all my old battery cable out
Taking my old valve covers off
I like my new valve covers
#69
Starting to remove my battery, tray, and ECM mount
Running some 0/1 gauge welding cable
After a lot of measurement and deciding. I finished my cabled and added some mesh and heat shrink
Found my location for my mega fuse run
Got most everything mocked up for my wiring by the fuse box
Cleaned up my ECM harness a little but like the location of it. really free's up some space
#70
My felpros were leaking horrible so wanted to try these. They have worked well so far.
Defiantly a lot thicker
My coolant crossover line to remove my old rusted one. Will put the outlet in a better spot and dont have to run over the throttle body
My old setup
FYI i think its easier to remove header bolts with fenders out. have a direct access
Pretty please with how it turned out, no more junction box, coils, ECM tray. etc
My old setup
