Black LSX
Old Aug 13, 2023 | 04:47 PM
  #261
The_W's Avatar
Putting my e85 sensor on and I think I have been running my truck fuel lines backwards. The line coming from fuel filter should it go as your feed or return?
Old Aug 13, 2023 | 05:03 PM
  #262
The_W's Avatar
Nevermind I have figured it out. F..k I have been running my return line at feed and feed as return. Not sure how that is possible but glad I found out now. The return was plumed into my regulator. I had a buddy help me when o was building this and I bet they got switched. Because I ordered all 6an fittings and I cut what I thought was feed and the fittings were too big. Now I see why they are, I cut my return when I shouldn’t have. So now I need to cut the actual feed line install my sensor as it should. But have to order hose and fittings to fix my return line 5an. At this point I may just cut them back a little more and run nice hose up to both. Make my screw up worth while and look decent….hope that makes sense ugh!!
Old Aug 13, 2023 | 05:12 PM
  #263
silentbravo's Avatar
5 Year Member
It's feed on my truck, definitely 3/8" from tank to fuel filter on frame, then continuing on up to rail.
Ah just a moment to late... that's why I plan to run a new line by itself and just remove or cap off the old lines (plus I need to bypass the stock filter). I may go for -8 feed too, just in case lol.
Old Aug 13, 2023 | 06:14 PM
  #264
smokinlmm's Avatar
Mine is on the return line straight off the regulator. It’s a 6an fitting and I’m running 8an feed so the sensor would be a restriction on feed line.
Old Aug 13, 2023 | 08:07 PM
  #265
The_W's Avatar
I heard it doesn’t matter on placement but you bring up a good thought on the sensor being a restriction to feed line.
I will probably keep them the sizes they are just replace with better hose compared to stock lines. I have ID850 injectors so I don’t think the lines will be restriction. Hopefully not!
Old Aug 13, 2023 | 08:33 PM
  #266
smokinlmm's Avatar
On the return line the sensor gets the fuel data before you start it.
Old Aug 13, 2023 | 10:11 PM
  #267
The_W's Avatar
That’s good info to know I appreciate it!
Old Sep 5, 2023 | 09:41 PM
  #268
The_W's Avatar
Got the engine and transmission in last weekend. Still have a ways to go.
Old Sep 6, 2023 | 09:17 AM
  #269
strutaeng's Avatar
5 Year Member
Looking great! 👍
Old Sep 17, 2023 | 12:11 PM
  #270
The LabTech's Avatar
Registered User
Awesome job! Keep it up!
