Black LSX
Old May 10, 2023 | 02:02 PM
  #221
The_W's Avatar
Just another update, engine is at machine shop we decided on which way to take it. The seized cam bearing didnt do enough to make the block useless. Since I am running a blower he want to try and get compression in the 9's. So going to bore the cylinder 30 over, and run a Mahle power pack piston on top. There was only like four hundreths of wear on cylinder walls. Bought a slightly used monster sc clutch, reservoir having made from snail fab, got track attack HX in, and a pierburg cwa100 hx pump. Just need cam and fuel pump.
Old May 10, 2023 | 05:40 PM
  #222
shakenfake's Avatar
Shlumpt
5 Year Member
The 9s? Definitely coulda done 10s
Old May 11, 2023 | 09:03 AM
  #223
The_W's Avatar
ya my current is 10.2.:1 it wasnt much to bore it out more like 300 dollars. But reading over on ctsv forums 10's are ok, running e85 will help as well. Apparently pistons are few and far between he said. They have had issues being able to get them on timely manner. Hoping it wont take them much longer, ready to start piecing this together to drive
Old May 12, 2023 | 01:28 PM
  #224
The_W's Avatar
Went looking around today for a new camshaft. I called TSP since I had decent service there last time. I know everyone is partial and or you can get a cam almost anywhere these days. I called them and they gave me this for my build. Also wanted something that would go with my top end that I already have. Just add boost component to it.
227/235, .641"/.649", 114 LSA
https://www.texas-speed.com/p-8554-t...-camshaft.aspx
Old May 12, 2023 | 07:48 PM
  #225
smokinlmm's Avatar
I have had good results with the cam motion/btr stage 3 Specs: 231/248 .617"/.595" 120+5
Old May 12, 2023 | 10:45 PM
  #226
The_W's Avatar
I may drop them a call Monday and see what they think as well. Thanks
Old May 15, 2023 | 10:14 AM
  #227
The_W's Avatar
Called BTR they recomended their BTR PDS Stage 3 torque cam. 226/25x .636/.636 112.5LSA
Old May 15, 2023 | 07:22 PM
  #228
smokinlmm's Avatar
I’ve got a 408 so that would make sense. What converter you running?
Old May 15, 2023 | 10:43 PM
  #229
The_W's Avatar
I have a manual transmission so no converter here. Tempted to go with the btr cam just to try something different.
Old Jun 11, 2023 | 03:52 PM
  #230
The_W's Avatar
What would cause this gauging on the deck and would it be of concern? Maybe piston hitting it. Was cleaning up my heads in prep to pickup my engine this week.
