Aunt Jemima
Old 09-19-2018, 11:39 AM
  #31
jfuegner's Avatar
Drag radials 295/65/15
Old 09-19-2018, 03:10 PM
  #32
01FormulaTA's Avatar
Looks good man, wheels turned out awesome!
Old 09-19-2018, 07:47 PM
  #33
silentbravo's Avatar
Sweeet. Wheels are definitely different but from the size difference someone may actually think they are the same brand/type just different sizes. Match pretty good.
I guess you need to paint your driveshaft now, since everything else under there looks so nice
Old 09-20-2018, 08:35 AM
  #34
jfuegner's Avatar
Thanks, I used the stock wheels because I had them. They will work for now. I change wheels a lot. Just couldnt spend the big money on fancy wheels, when it isn't going to affect the trucks performance. At least the way I use it. Painting the drive shaft is on the list. It does look pretty shi**y.
Old 09-20-2018, 12:02 PM
  #35
ls6musclehead's Avatar
What tail pipe kit did you use for your exhaust? It looks very nice. The rest of the truck as well.
Old 09-20-2018, 03:41 PM
  #36
jfuegner's Avatar
Tail pipe pieces are universal Walker brand tailpipes. I just ordered some that looked like they would be close and made them work. Here is the link to the exhaust build.
https://www.performancetrucks.net/fo...member-549690/
Old 11-08-2018, 12:11 PM
  #37
jfuegner's Avatar
Working on a gauge pod. I didn't want anything on the pillar or around the dash so I decided to go with this. I plan on running auto meter cobalt gauges the blue will match my factory cluster with the LED upgrade. I plan to run two gauges trans temp and air fuel ratio. The switch is for my line lock.
Old 11-08-2018, 03:57 PM
  #38
Nice. Did you buy the angled gauge pods or make those pieces?
Old 11-08-2018, 04:21 PM
  #39
Teeny05's Avatar
What drop do you have? Im working on picking up a set of those tires when I can afford it, just wondering how it will look. Yours look sick.
Old 11-09-2018, 06:22 AM
  #40
jfuegner's Avatar
The rings are from Auto Meter part #2234.
Quick Reply: Aunt Jemima
