Aunt Jemima
#33
Sweeet. Wheels are definitely different but from the size difference someone may actually think they are the same brand/type just different sizes. Match pretty good.
I guess you need to paint your driveshaft now, since everything else under there looks so nice
#34
Thanks, I used the stock wheels because I had them. They will work for now. I change wheels a lot. Just couldnt spend the big money on fancy wheels, when it isn't going to affect the trucks performance. At least the way I use it. Painting the drive shaft is on the list. It does look pretty shi**y.
#36
Tail pipe pieces are universal Walker brand tailpipes. I just ordered some that looked like they would be close and made them work. Here is the link to the exhaust build.
https://www.performancetrucks.net/fo...member-549690/
#37
Working on a gauge pod. I didn't want anything on the pillar or around the dash so I decided to go with this. I plan on running auto meter cobalt gauges the blue will match my factory cluster with the LED upgrade. I plan to run two gauges trans temp and air fuel ratio. The switch is for my line lock.
