5.3 \ 72mm / 80e \ Ecsb build.....
#22
#23
#25
Update! Got the walbro 255 fuel pump installed tonight and dropped the oil pan so i can get it tapped for the oil return. Started on removing the LT's but they were being a bitch so i decided to call it a night.
Tomorrow i will have all day to work on the truck, should make decent progress. Heading to the dyno next Saturday for the Tune!
#26
Worked on the truck about 8 hours today and made some good progress. Got all the hot side bolted up, new plugs, oil pan bolted back on, and got the turbo clocked. Got the bumper off and started with the cold side before calling it a night.
Still need to mount IC, get some oil,filter, bolt on the wastegate, and BOV
#30
Finished every thing today except for the injectors, I plan on taking the truck to the muffler shop tomorrow to get the exhaust work done. Intercooler went on pretty smoothly and i like how it turned out. Now I just need to cut a hole in the lower valence for some air flow!
I have the red filter on the turbo for now, I plan on using the AFE cold air intake I had when i was N/A and run an elbow to the turbo for a cleaner look.
