4wd conversion
Old Feb 8, 2011 | 12:52 AM
jerrynaranjo08's Avatar
i did this conversion on a 2002 yukon 2wd to AWD i took all the parts off a burned escalade...everything is pretty much the same the only parts i used were the axles, wheel hubs, front diff, transfer case and tranny, i used the crossmembers but had to modify the frame cause 2wd and 4wd are different....also had to fab the mounts and brackets for front diff.
Old Feb 8, 2011 | 01:12 AM
BadAssChevy327's Avatar
that swap was easy for you because tahoes sit on a torsion bar front end. his truck has coil sprung unless its a 2wd SS/vortec max/ some of those werid silverados that just came with it. if your frames good lets meet and trade cause i hate this torsion bar **** i want a coil sprung front.
Old Feb 8, 2011 | 04:51 PM
1989k1500's Avatar
All the Yukons/Tahoes/Suburbans have the same suspension whether they are 2wd or 4wd. Trucks arent like that.
Old Feb 8, 2011 | 05:19 PM
True but even the truck front end suspensions are the same the only change is the rear end leaf spring on trucks.
Trucks also have the front end torsion bars same setup as SUV
Old Feb 8, 2011 | 08:59 PM
blackcash's Avatar
Only the 4wds and 6.0 1500s. The rest are on coil springs
Old Feb 8, 2011 | 09:07 PM
viciousknid's Avatar
Where's the Beef?
I have a 2wd and a 4wd 5.3 1500's. 4wd is on torsion, 2wd on coils.
Old Feb 8, 2011 | 09:18 PM
1989k1500's Avatar
The 4wd trucks have torsion bars, and the HDs, SSs, Vortec Max, and VHO trucks.
Most 2wd trucks are coil sprung.
And since his is a 2000 its going to be coil sprung. Its completely different from the torsion bar trucks.
Pimpinpete
43
Dec 22, 2017 08:13 AM
Silver8ado
Sep 30, 2015 11:42 AM
Blklgt
Sep 28, 2015 03:21 PM
sTNT971
Sep 26, 2015 04:22 PM
spooneralmighty
Sep 11, 2015 02:28 PM
