2004 Silverado RCSB build...
Has anyone buy products from Mike Turbo (http://miketurboinc.com/ Is their service good or bad?? I just want to know before I want to buy their product(s). Thank you.
Dang, I been search for different brand name turbo for compare. I think I getting turbo Borg Warner S400SX 80MM T6, 1.10a/r and KB racing's kit.
I decided what i want for 6.0 370ci and will use 317 heads.
-Wiseco Forged LS1 Piston Set: 4.030' Bore, 3.622' Stroke, 6.125'
Rod Length, 1.300' CH, -11cc Dish; Includes Wrist Pins & GFX
Steel Top/Napier Second Ring Set
-Callies Compstar 6.125' H-beam Connecting Rod
-Cometic LS1 Multi-Layer Steel Cylinder Head Gasket, Per Gasket,
4.035 Bore, .045 Thick
-ARP 12 Pt. Head Stud Kit
-ARP Main Stud Kit for LS1/LS6
-Clevite LS1 H Rod Bearing, Per Bearing
-Clevite H Main Bearing Set, For LS1 Stroker
- cam-22X/22X-, 11X LSA.
- Do need to put new all Hardend push rods, lifters, springs?? what else ?? I try to remember what else.
-High volume oil pump
-4L80E stock-Transgo hd2, Circle D 3200 multi disk or single. I not sure which one.
Crossmember
- Fuel system- Need to figure out what to do with a fuel pump twin 255 and 60 or 80lbs fuel injectors.
I think that's all. but I not sure if need more list what i have lists here for 6.0 and 80E.
Crossmember
I got 6.0 engine and 80e. I will put some pics. I can't use the bellhousing bolts on the motor stand. I'll have to buy longer bolts to put it on a motor stand. I don't know the size of the bolts through and what brand name bolt won't get break or bend. Anyone know what size of the bolts ??
