2004 Silverado: 4.3L to SBC swap
Hello everyone.
Following the thread on the build of my Small Block Chevy. https://www.performancetrucks.net/fo...d.php?t=420932 The swap has began. Sept 6th, 08: Parked the truck, removed a few body panels. Disconnected the battery, drained the coolant. Removed the radiator hoses, removed the accessory brackets- Alt & PS pump. Unplugged all of the engine sensor harnesses, unhooked the Y-pipe from the headers. Removed all of the bell housing bolts, disconnected the torque converter from the flexplate. http://i40.photobucket.com/albums/e2...tall/First.jpg http://i40.photobucket.com/albums/e2...all/Second.jpg Modified the A/C bracket & spaced the A/C compressor to work with the tall valve covers. http://i40.photobucket.com/albums/e2...terferance.jpg http://i40.photobucket.com/albums/e2...ll/bracket.jpg http://i40.photobucket.com/albums/e2...bracketmod.jpg http://i40.photobucket.com/albums/e2.../Bracketon.jpg http://i40.photobucket.com/albums/e2...l/ACspacer.jpg http://i40.photobucket.com/albums/e2...tall/357ci.jpg Unhooked all of the engine wiring harness & brackets from the motor and began to pull. http://i40.photobucket.com/albums/e2...stall/Pull.jpg ..and pull http://i40.photobucket.com/albums/e2...tall/Pull2.jpg and than tug http://i40.photobucket.com/albums/e2...tall/pull3.jpg and drop http://i40.photobucket.com/albums/e2...tall/pull4.jpg This is where I am at, after a short break and cool down from the 90+ degree heat out there. This afternoon/evening I plan to change the torque converter out for my 3000 stall unit, change the motor mount brackets for the V8 ones, and splice the V8 fuel injector plug in onto the 4.3L harness. Cheers ~Mykk |
Finished up day one by:
tossing the V6 motor mount brackets and bolted in the new V8's http://i40.photobucket.com/albums/e2...l/MountsTC.jpg Filled up the new 3000 stall locking torque converter and stabed it into place. http://i40.photobucket.com/albums/e2...tall/NewTC.jpg Started grafting the V8 plug to the harness http://i40.photobucket.com/albums/e2.../GraftPlug.jpg Repinned the PCM to match the V8, inclduding running two new leads http://i40.photobucket.com/albums/e2...tall/repin.jpg http://i40.photobucket.com/albums/e2...all/Repin2.jpg Tomorrow is another day Cheers ~Mykk |
Lookin good so far. You are going to love the power of that motor compared to the V-6.
Looks great Mykk! I'm really excited to see how this thing comes together.
VERY NICE! :D Can't wait to see how she runs! :D
very interesting on this whole concept/build.
one question comes to mind tho. with inspection/emissions. i wonder how the local laws will look at this |
Originally Posted by 7845
(Post 3995554)
He is in Phoenix and as long as it passes the OBDII plugin test, and has no codes, no problem. They don't really do a visual, not could they tell the motor is any different, :lol: Thunders truck just passed, :jest:
EDIT: Chris beat me to it, :lol: |
I'm in Prescott, there are no emissions tests.
Originally Posted by 04SilveradoMykk
(Post 3995569)
