1984 K5 Blazer
Finally got my own project! It's a 1984 k5 blazer. Just bought it today and haven't even seen it. My brother in law went and checked it out for me. List of mods are below:
Lift: 9 inch’s -5 suspension -3 body lift -new body bushings Axles Front: -Dana 60 king pin joints -30 spline -Open Carrier -Manual G2 hubs -3:73 gear ratio -1982 K30 axle Rear: -GM 14 Full Floating Axles -Limited Slip -3:73 gear ratio -1982 K30 axle Winch: -12k Gorilla winch -Wired and wireless remote Tires: -5qty 38x15.5x20 10 ply (Full size spare) -Nitto Mud Grapplers Extreme -Lots of tread Engine: -Rebuilt engine has less than 10k miles -Chevy 350 4 bolt main bored 60 over -Holly Intake Manifold -Edelbrock manuel choke -RV cam -4 core radiator from 454 engine. Transmission: -Turbo 350 -208C Transfer Case Interior: -Bed line fully inside -Simple speaker system with 6x9s It needs some body work and rust repair but most do at this age. Going to be a project for my daughter and I and once my son is born hopefully him to. I can't wait to go grab it next weekend. Should go well with my dad's 77 bronco we just finished. https://cimg1.ibsrv.net/gimg/www.per...7f5b15c15e.jpg https://cimg2.ibsrv.net/gimg/www.per...c8a34e158c.jpg https://cimg5.ibsrv.net/gimg/www.per...10f20a36d5.jpg |
Looks well used, got a long road ahead of you.
What are your end goals? |
Father daughter project//tinker toy//cruiser//deer lease//off roader//fuck around vehicle. Body panels are cheap so no worries about replacing those. First thing I'd like to do is convert it to a 5spd manual and get the AC hooked back up and running. Then get the rust fixed (thankfully it's a Texas truck). Then build the spare engine up that I've got and drop it in. Then roll cage and paint. But let's see what happens. For now I just want to drive it and have fun with it.
Damn no kidding! Thing is a monster!
Drove it around yesterday for a while. This thing is so white trash it's awesome. Actually drives half decent for being what it is. Had my copilot with me also:
https://cimg5.ibsrv.net/gimg/www.per...e4d3abbb26.jpg Went out this morning and it was dead. Nothing clicked on. Hooked up some cables and still nothing. Hmm. Brand new gel battery only had 3v. Pulled the alternator and it spun a little to freely. Went and had it tested and it was putting out 0.0v. Bought a new one of those. Also noticed the radiator was low on coolant so got some of that. Got some rear view mirror adhesive so I can get that glued on and then I can take the front doors off. I'm going to rig up a pulley system to take the top off tomorrow. Does anyone know where I can buy a whole new tail gate for this thing? I can find tail gates for the pick ups or non removable tops all day but not ones that have the glass inside them. Otherwise it's time to buy some sheet metal and get to patching. |
https://cimg1.ibsrv.net/gimg/www.per...c18aa9be58.jpg
Found the original options list in the glovebox. Had factory quad shocks up front and the mounting points are still there. Factory AC. Originally a 302 with a 4 spd auto. Two tone paint with one color being black. Which tells me the black I'm seeing beneath the white on the fenders is probably original. To bad every body panel is trashed from rocks. |
Not much going on here. Relocated the aftermarket gauges from the bottom of the dash where you can't see them to the factory locations so you can see them. Ended up being a lot harder than it should have been as the oil pressure and water temp were mechanical so I was having to pull out copper tubing and whatever the water temp hose is. But they all work and no leaks and now the lights on them actually work also.
https://cimg4.ibsrv.net/gimg/www.per...8ebce9b8ee.jpg |
Took her out to Hidden Falls adventure Park today for some rock crawling. Had a great time. This thing can definitely do more than I have the skills for. Once I get some of the videos from my GoPro loaded up I'll post some.
https://cimg2.ibsrv.net/gimg/www.per...f2d52003b3.jpg https://cimg4.ibsrv.net/gimg/www.per...85223a2097.jpg |
| All times are GMT -5. The time now is 04:09 AM. |
