06 ecsb 6.0/80e swap skreet truck build
#43
1600 miles on the swap so far. Getting dyno tuned next monday so we'll see how that goes. This thing is a blast. Mpg is god awful, burned through a whole tank of gas in pretty much 2 days driving around, oh well atleast it sounds cool.
Also raced a ccsb lb7 with a s369 and some other ****, I lost first one cause he got the hit on me but second race I got out and stayed ahead, definitely surprised the hell out of me!
When racing the passenger said my wheels were shaking pretty bad up front. The front end of my truck has never really felt fully stable with drop spindles, even with the coilovers. Has anyone else ever had this problem? Any suggestions of what to look at? Every single piece on the front end is new. Ucas, lcas, steering rack, tie rods, sway bar, links.. coilovers obviously...idk Im pretty convinced that drop spindles are garbage. I've ran the mcg 16 and 17 and they both suck.
#47
Truck looks awesome.
The missfire issues are causing your converter lock up problems... can almost guarantee that. The PCM wont lock up while it knows (or thinks) there is a miss.
Can you feel the miss? Can you describe when it seems to do it most? It may just be some settings in the tune that should be changed post cam.
#48
#50
Turned out to be a misfire! Number 7 had an intermittent miss which is what was throwing the code every now and then. Pulled the wire off and peeled it back, sure enough it was torn from being burned. The shop I took it to acknowledged there was a problem but chose to tune around it which made it run so so much worse. A friend of mine and local tuner took 5 minutes out of his day to find the problem, then spent the rest of the night re tuning it on the street. Man what a night and day difference! This thing rips, Im so happy lol
