05 5.3 80mm turbo v6 swap
I bought this truck in august of 17 as a daily for work. This project soon began to go severely off course. We started with a McGaughy's 4/6 drop 22" DUB wheels. Soon after driving the truck I just realized it had very little power and didnt like the V6. I began working on on of the spare 5.3 motors for another project here is were it went completely off the rails. Motor-04 tahoe 5.3 70k on it, Texas speed 228r cam, a set of 243 head off a corvette. LS9 head gaskets, ARP head studs. this is where I thought I would stop but my son shop works for a custom car shop said we should go with gen 4 pistons and rods and a turbo. I opened the check book and began to drain it fast. We now have a gen 4 motor, VS racing 80mm turbo, Huron speed manifold and all the turbo goodies, Turbosmart controller ETC, ETC, We completely took the truck apart down to the frame to begin our build.
Before
4/6 drop and new wheels
Gen 4 rods and pistons
243 heads
Boxing in the frame
Before
243 heads
Boxing in the frame
Sometimes a guy's gotta do what a guy's gotta do! Nice!
More pictures of the progress so far. Started the coil over conversion today.
used 1/2" aluminum hard line for fuel lines
Mounted new rear Ridetech shocks Drive shaft loop installed motor
test fit the new 3.5 aluminum driveshaft.
Mocked up the cross over pipe
Used 1/2" hard line for the fuel supply, 1/4" hard line for the steam ports,
Drive shaft loop
Drive shaft loop
Cool project!
I'm curious what you do for a fuel tank and where you put it. I too have similar frame bracing where the stock tank would be, so I have a cell in the bed. It was the easiest option to get me running many years back, but i hate leaving the truck in the hot sun, baking the fuel. I'm looking for ideas to place the tank/cell behind my axle, under the bed.
Good luck with the project, it looks very good.
Cool project!
Finished the coil over conversion this last week and finally painted the frame. For the frame I used the summit racing chassis satin black I was skeptical about using the summit brand of paint after I was done it looks great and I was amazed at how well it was it sprayed out even with a cheap HF gun. Items for this week so the cab can go back on. Finish engine oil pan install. Rear main gasket. Install torque converter and mate trans and final install in frame. And finish wiring harness
Coil over installed
Painted the frame with Summit Racing chassis satin black.
Coil over installed
This week I reinstalled the hard lines for the fuel, vapor purge and return fuel lines. Cant forget trans cooler lines also and the ABS control pump and brake lines for the front and back brakes. Today my son and I dropped the cab back on to the frame.
Quick update It has taken me a few weeks to clean the rear end and install new 3:73 gears and a tru trac . I have never installed gears before after many trials and errors I think I have it. If anyone has installed gears let me know your thought. Back lash is set at 7. And pattern looks good.
