window switch I am new to nitrous
Old Mar 14, 2008 | 09:10 AM
LS1GMCTruck's Avatar
Question
Originally Posted by slowprocess
Just remember the stock trans is on borrowed time, regardless of a window switch or not. 2 of my built transmissions didn't even get a dose of the gas and they still left me with two gears. I lost 1 spraying a 100 shot with a window switch, 2 with just motor passes, 1 on a 150 shot spraying through the shifts, and 1 on a 2 stage 200 shot spraying 100 out of the hole and 100 in second gear all through the shifts. I've given up on the 4l60e all together now.
So, whats the answer to the tranny/nitrous dilema, a 4L80E? Could they take the abuse?
Old Mar 14, 2008 | 02:26 PM
LowBlack99's Avatar
I've been spraying a 80 shot on a stock 4l60 with a stock tune except for a hypercrap to change shift points and firmness for 5 years and 50k miles now and have been very fortunate that it has held up. My results are not typical, I would have expected it to crap on me by now. I have a dry kit on a momentary switch so I control the spray but I do spray through the shifts. One thing that is probably helping is the hypercrap does not eliminate the factory torque management? I in no manner endorse the hypercrap, It was free and I have yet to take the plunge to a tune until I get a few more bolt ons, cam etc... It's a daily driver and as well and dosen't get driven hard on the spray very often anymore.
Old Mar 15, 2008 | 07:36 AM
slowprocess's Avatar
You know, I've been pretty amazed at what these built 4L65e seem to be able to take from guys on the board. Looks like that is the route to go without gaining all of the weight and extra expense of going to the 80e. I'm just not a big fan of the stock 80e gear ratios.
Old Mar 15, 2008 | 10:55 AM
WFOsierra's Avatar
I thought about buying a transgo kit for my l65. Is this a very hard project that would require some professional work?...I am going to buy a 2600 stahl converter soon and i was gonna do the transgo kit first. Plus some servos
Old Mar 15, 2008 | 11:21 AM
Many nonprofessional people have installed the shift kits, but I've always been alittle scared of tackling it myself. I've dropped a valve body before and it just seems to particular to work with for me personally. The servos you can handle with no problems, but if you have any doubts, let someone else drop the valve body and install the shift kit.
Old Mar 15, 2008 | 04:08 PM
TXsilverado's Avatar
buy a built 60/65e from a reputable builder and spray through the shifts IMO.
shutting off the spray before the shift is like putting torque management back into the motor. performabuilt and FLT seem to be the 2 that build 60e's to take some serious punishment
Old Mar 15, 2008 | 09:05 PM
silver-mod-o's Avatar
Hunt&Fisherator
I have sprayed through PLENTY of shifts with my FLT lvl 5 4L65E trans with a 150 shot... I wouldnt be scared to get in it and drive anywhere right now... you get what you pay for IMO...
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
Closer_2001
Sep 24, 2015 09:15 PM
gavin2005
Sep 13, 2015 09:04 PM
