Timing Numbers Needed For N2O
Old Sep 14, 2005 | 07:32 PM
Default Timing Numbers Needed For N2O
I have a question about timing and nitrous. I am using a 150 shot of Gas on my 5.3L, I wanted to know how much timing to pull off the timing band. I blew a piston already and i don't want to blow another one yet Can any one help i have access to HP Tuner for tuning. HELP PLEASE???????
2004 Chevy LS
RC/SB
LM7 5.3L
4l65E w/SHIFTKIT,SERVO
G80 w/3.73
ADD ons: LS1 electric Fans,TB bypass, TB spacer, 160* Thermostast, K&N Cold air induction, Borla ProXcess Muffler w/Turndows, NitrousWorks 150 shot, HP Tuners Tune, 295/50r16 BF GOODRICH radials.
Future Mods 6.0L, patriot 5.3L Stage 2 head and cam kit, Vigilante stall, 4.10 gears Longtubes and OFY pipe, TNT N2O set up.
AGGRESSIVE MOTORSPORTS live life at full throttle......
Old Sep 14, 2005 | 08:46 PM
slowec's Avatar
I pull 4 out w/ my predator. And I shoot da 150
Old Sep 14, 2005 | 09:39 PM
KLUG'S SS's Avatar
FormerVendor
Something that you might want to consider is to get a timing tuner, with this you can run full N/A timing all the time and then when you spray you can adjust it to pull timing out.
The timing tuner that I am looking at purchasing is about $250 which I think is well worth it because from what I understand it also has a built in window switch. Just something to think about
Old Sep 14, 2005 | 11:14 PM
yes
Old Sep 15, 2005 | 05:56 AM
one03sierra's Avatar
Formerly one92rs
Talking
i was shooting a 150 and a 175 shot on my old 5.3. i was running 30* timing as well. i used the timing tuner at one time. man did it pull timing. it does work and work well. make sure all your connections are perfect. i ended up taking it off. i ran tr55ix iridium plugs with msd wires. a missfire and you are going to be toast. do you run a fuel pressure gauge?
Old Sep 15, 2005 | 05:47 PM
where can i find a timing tuner what brand and is it well worth it. abiut the fuel PSI gauge i am waiting for the pillar pod and N2O & FUEL gauges from auto meter i am using tr6 ngk spark plugs...
2004 Chevy LS
RC/SB
LM7 5.3L
G80 w/3.73
Old Sep 15, 2005 | 06:17 PM
Formerly one92rs
Talking
tbyrne sells the timing tuner.>>>>>>>>>
http://www.tbyrne.com/ls1catalog.html
Old Sep 15, 2005 | 08:27 PM
Thanks for the tip on where to find it i wil buy ASAP. One question i have wil it work with a custom HP Tuners Tune that i have in my truck...
2004 Chevy LS
RC/SB
LM7 5.3L
G80 w/3.73
Old Sep 15, 2005 | 11:29 PM
KLUG'S SS's Avatar
FormerVendor
2004 Chevy LS
RC/SB
LM7 5.3L
G80 w/3.73
Yes it will work fine with your tune, it installs inline with your crankshaft position sensor to alter the timing. I don't even have one yet but it seems to be a damn good product, the f-body guys over on ls1tech that have the timing tuner seem to really like it.
If you haven't done it yet go over to tbyrne's website and read up on it.
Old Sep 16, 2005 | 01:38 AM
Grey Silver's Avatar
11 Second Club
Timing tuner? No thanks. I run 24* for a 150 shot and check it w/ the scanner to adjust it. A/F is real important, you can run leaner w/ less timing and that's where the power is at.
