Putting a bottle in my toolbox. Too hot?
Well I just picked up my nitrous kit and I'm gonna run a 125 wet shot. I'm planning on having the nitrous setup hidden and I was going to put it in a small toolbox I have in the bed of my truck. I also have a tonneau cover as well. I mainly wanted to put the bottle in the toolbox so it doesn't get stolen or so it doesn't get hit with a baseball bat or other crap I keep in my truck.
So my question is: Do you think this setup is going to get the bottle too hot? I live in Austin Texas and it gets up to about 110* down here. The bottle will obviously be out of direct sunlight, but it gets pretty hot under the tonneau cover. Does anybody have any suggestions to setting everything up? I don't want to have the bottle blow up underneath my tonneau cover |
Just hook up a blowdown tube and aim it down thru the bottom of the bed.
I just want to know if what I'm doing is smart or if anybody else is running a nitrous bottle in a location that is prone to high temperatures. |
The bottles are designed to hold alot of pressure. We leave our Nitrogen, Oxygen, Asclyten bottles out side in the direct sunlight the pressure might rise an addition 100-500psi but thats it. Look at it on the bright side... atleast your bottle is goin to stay warm... :judge: I wouldnt worry about it, sounds like a good idea.. out of sight and locked down.
Go for it |
Go for it Now, so I can kill 2 birds with one stone.... What do y'all think about me doing a WOT switch and pushbutton setup so I can spray exactly when I want I have a window switch but I like the idea of being able to spray when ever I want so I can adjust depending on traction issues and stuff. |
The bottle won't blow until it hits 3000psi. Then, it'll bead blast everything in your tool box. The blowdown tube is a smart move.
The WOT switch is your spray button. If the system is activated, it just works. Dunno why you'd add a second switch? The WOT switch from DynoTune can be trained to activate at any throttle position. |
Originally Posted by RandomHero
Sweet, that's sounds good!
Now, so I can kill 2 birds with one stone.... What do y'all think about me doing a WOT switch and pushbutton setup so I can spray exactly when I want I have a window switch but I like the idea of being able to spray when ever I want so I can adjust depending on traction issues and stuff. That what i was goin to do.. WOT switch and a Button..... WOT switch is to insure that your are actually at WOT. and the GO button to spray on command... pretty cheap way to do it. |
I'm totally confused. If you're already running a window switch, why would you add a button after the WOT switch? Why use the WOT switch at all?
I picked up a nitrous express kit complete with everything plus a window switch, bottle heater. I want to just run a micro switch and push button switch. It's my understanding that if I wire them together, the system won't spray unless both are engaged meaning I'm WOT and I'm pressing the button. EDIT- The reason why I would add a button after that is because I don't want to spray through shifts, I can have control of when I spray out of the whole to maximize traction, and because I like the idea of having full command of the nitrous. The push button is like $10 so I figure if I don't like it, i'll just ditch it and run the micro switch |
already told you what I thought and my experience it will be fine
