Purge valve leaking
Old Apr 13, 2016 | 06:45 PM
XBlackXCheavyX's Avatar
Default Purge valve leaking
So I got around to installing my purge today, once I got it installed in hooked the bottle up to check for leaks, well it's leaking from the purge port and the n2o port, I tighten everything up and it still leaks, so I tighten it up some more and still leaks, I'm afraid if I try to tightne anymore I will mess the threads up, it's brand new just ordered it a few weeks ago so I don't know what would be causing it, i checked to see if their was anything on the threads and nothing, any input would help, thanks.
Old Apr 14, 2016 | 09:49 PM
Blwn99x's Avatar
Is it leaking from the threads or acting like the solenoid is open?
Old Apr 15, 2016 | 03:22 AM
SRTKLLR's Avatar
Did you use Teflon paste or thread locker? If not, then that is the problem. The fittings that go into the solenoids are NTP.
Greckum
Oct 26, 2016 10:06 AM
BLOWN 364
May 18, 2016 11:09 PM
lxcoupe
Apr 11, 2016 05:47 PM
Jake75
Apr 5, 2016 12:51 PM
madmann26
Mar 21, 2016 05:56 AM
