-   NITROUS OXIDE (https://www.performancetrucks.net/forums/nitrous-oxide-160/)
-   -   Which Progressive Controller (https://www.performancetrucks.net/forums/nitrous-oxide-160/progressive-controller-454513/)
Last Call Jan 2, 2010 02:35 PM
I cant decide between the FJO and Microedge+ progressive nitrous controllers.
For those of you running either of these controllers, can you tell me how they have worked for you? What you like/dont like about them?
If there are other controllers I should consider, feel free to make suggestions.
TXsilverado Jan 2, 2010 03:21 PM
FJO is the shit.
nxredsled Jan 2, 2010 04:24 PM
im very pleased with my microedge everything i have is from hsw and im very happy with everything ive ordered from them
Last Call Jan 2, 2010 04:28 PM
Originally Posted by TXsilverado (Post 4364748)
FJO is the shit.
What do you like about it? Does it have a lean cut off feature?
Is it the Microedge Regular or Plus? Is it easy to program?
nxredsled Jan 2, 2010 04:34 PM
It is the plus and i thought it was easy to work with, the install is alot of wiring, but the instructions were very detailed.
Last Call Jan 2, 2010 04:37 PM
Awesome, thanks for your input!
nxredsled Jan 2, 2010 04:39 PM
No problem
TXsilverado Jan 2, 2010 05:04 PM
no lean cutoff. but.
plug in your laptop to your nitrous system and you have 100% of who what when where and how 2 stages of nitrous can apply. you can download the program for the FJO controller on the site and see what im talking about.
it's a window switch for 2 kits, you can run 2 kits progressive, you can ramp it by time or rpm, you can disable it until a certain rpm, you can delay it by tenths, you can do a first gear lockout....just download the program and check it out.
the only thing i dont like about it is the progressive function...it works, but after having it, i will never run a progressive setup. which is cool, because you dont HAVE to run progressive with the FJO. i just run it as a full controller for both of my kits. 125 on the first kit at 100% throttle and the 2nd kit kicks in as soon as it hits 2nd gear (or it will once its all installed)
Last Call Jan 2, 2010 08:52 PM
Cool, thanks man. Good info!
What didnt you like about the progressive set up? How hard it is on the solenoids?
TXsilverado Jan 3, 2010 01:41 AM
just after running the progressive, you realize how much better a dual stage kit would work. on a 125 shot, my best times were without the progressive. i wouldnt try a 150 out of the hole (on my setup)if your plannin 175+ on a single kit its probably worth it but you can always do better hitting that 1 kit that you launch best on, then pouring on the rest with a 2nd kit.
