As I understand it most DI engines have this problem and especially when you add boost to the mix. My wifes old Hyundai Veloster turbo 4cyl. would have 1/2-3/4 full catch can every oil change......
Do you have more pics of the setup?
Did you only need 1 catch can? These trucks have 2 vacuum lines so I'm just trying to make sure 2 cans aren't needed.
The problem on DI engines, is you have no fuel flowing past the intake valve so you get massive carbon build up on the valves from the PCV. Been a known issue with VW/Audi for the last 10 years.
