Nitrous Installation
Old Mar 25, 2009 | 04:16 PM
05zilverado's Avatar
Registered User
Default Nitrous Installation
Hey guys new to this forum and new to nitrous i have a 2005 silverado with the lm7 and i just ordered a wet kit from nitrous outlet and i have the ngk tr6 plugs and i am not sure how to tie into the fuel line i was wondering if any of yall could email me some pictures or something to help out with the install cause i am not sure exactly how to do it and the instrucitions on nitrous outlet are not really specfic plus i have ordered the window switch and a fuel pressure gauge any help is apperciated thanks
Old Mar 25, 2009 | 04:27 PM
03tahoe22's Avatar
There is a schrader fuel pressure check valve on the fuel rail on the drivers side of the intake possiblly under the cover. That valve needs to be remove with a special tool and that is where you can thread on the fuel line and fuel pressure. Plugs are gapped to .035? The green wire coming off of your throttle body harness if for the wot activation....
Old Mar 25, 2009 | 04:31 PM
A Low Dime's Avatar
13 Second Truck Club
You can use a valve core removal tool, which is what you also use to take out a valve stem from a tire. They only cost about $5.
Registered User
okay and yea the plug is .035 as far as the special tool for the fuel vavle where would i get that i know this is alot of newb stuff but i just want to do this right the first time and avoid detonation
Old Mar 25, 2009 | 04:33 PM
Registered User
alright i will be getting one and as far as the window switch it plugs to what excatly
LCHEE
Oct 24, 2020 04:10 PM
Greatdivider
Sep 9, 2015 09:52 AM
southernsmoker
Aug 31, 2015 03:09 PM
zblee
Aug 3, 2015 03:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
