nitrous button
Old Jun 10, 2011 | 10:11 PM
twgoodspeed's Avatar
Default nitrous button
im wanting to use my tow haul button on my shifter as my nitrous button, any ideas
Old Jun 10, 2011 | 10:36 PM
2007chevy5.3l's Avatar
Umm I wouldnt do that. Just use a full throttle switch. Thatd be 100x's easier to wire up anyways
Old Jun 10, 2011 | 11:03 PM
beingblueeyes's Avatar
are you talking about using it as a arming switch or activation switch?
Old Jun 10, 2011 | 11:42 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
It's a momentary on switch. Holding it down doesn't do anything. You might be able to use it to arm your nitrous system, but then you're giving up your tow/haul transmission programming in the PCM. I don't really think it's worth the tradeoff.
Old Jun 11, 2011 | 07:54 AM
custm2500's Avatar
Ph.D. in HUBRIS
A momentary switch usualy stays closed if you hold it.
If you find the tow haul wire near the base of the colum it will be VERY easy. You splice the tow haul wire and install a new tow haul switch somewhere else in the truck. Use the TH switch to turn on your relay for the nitrous and wala.
I did this years ago with my probe and the O/D button. Window switches were not cheap and honestly 10 years ago I don't think they were used by much anyone besides the pros. For $100 bucks it is much nicer to have a window switch so that the nitrous practicaly runs it's self. You arm it and that is it. The window switch does basicaly everything from there.
If you want it on a button then as I explained it shouldn't be hard at all, just need to find the color and location of the TH wires.
Old Jun 11, 2011 | 01:47 PM
Spoolin's Avatar
GFYS and STFU
Not sure it's the best idea to be using that switch, but if can be done.
simman22
Jan 21, 2017 10:27 PM
turbo6c3
Oct 5, 2015 06:11 PM
gavin2005
Sep 13, 2015 09:04 PM
gmcyukon
Sep 7, 2015 08:46 PM
06murder
Sep 4, 2015 03:54 PM
