Newb question
Old Feb 3, 2006 | 03:50 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Default Newb question
I've never been a bottle guy, but...
So why is a direct port kit better than a plate kit of the same size? For example, if I had a vic jr carb style efi manifold, why would the port kit be better ?
Second: If I already have a second fuel pump (twin 255 lphs) that comes on when I hit boost, do I need yet another pump for a wet kit?
Old Feb 3, 2006 | 04:54 PM
Matt@HSW's Avatar
FormerVendor
With a direct port the same amount of fuel and nitrous is being injected into each cylinder. With a plate/nozzle set up each cylinder will be receiving a different amount. With a direct port you can also tune each individual cylinder. The fuel pump issue will depend on how much power you are making now and how much you will be spraying.
Matt
Old Feb 3, 2006 | 06:32 PM
I AM A MOTHERF*CKER
Thanks Matt, makes perfect sense now
JordanH
Dec 25, 2015 08:32 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
